New bolts for exhaust elbow.
Thresher
19 Aug 2002
Tollesbury
Having managed with great difficulty to remove the stubs of the sheared bolts from the cooling pipe that attaches to the exhaust on my volvo md5b I now have to fit replacements.
They have lasted 35 years so I'm sure it won't happen again before the engine is replaced but what can be done to prolong the life of the replacement bolts. Should I use stainless steel bolts? add grease? some other compound to keep the two surfaces apart? I have some chromium oxide paste, could I use that?
cryan
5 May 2013
Kirkcaldy, Fife
www.cryco.co.uk
Copaslip, copaslip, copaslip. Not only will it stop galli g and seizing it slows corrosion too. When I was an apprentice one of the old boys told me to never put a thread or gasket together dry unless the manual specifically states it. A very wise man!
Poignard
23 Jul 2005
South London
Coppaslip it is then. What is galli g?
Galling is something that happens with stainless steel nuts and bolts, for example. Sometimes, when they are tightened together the mating surfaces bind, making it very difficult, or even impossible to get them apart.
One way round it is to use an anti-galling compound on the threads, eg AG90 ( http://www.actioncan.co.uk/portfolio/ag-90-anti-gallinganti-seizing-lubricant-h1-food-grade/ ). Coppaslip or ordinary grease can also be used but I'm not sure if they are as effective.
Last time I had this happen was with a bolt and nut holding down a mast step. I was doing a trial assembly and didn't bother to treat the threads because I didn't intend to tighten down hard. Even so, it was imposible to unscrew it and there was no access to allow of sawing through it. It was Sunday morning and I was in a hurry so I had to buy a nut-splitter from Halfords (rubbish quality, btw!) to break the nut free.
Now I carry a tin of AG90 on board and use it on any s/s threads before assembly.
