New Boat Purchase
pvb
UK East Coast
I'd agree with the view that larger boats are often easier to handle in marinas, etc. However, I think there's a point at which manoeuvring singlehanded maybe gets fraught, and I'd have thought it was a bit smaller than 49ft.
lustyd
27 Jul 2010
Of course it was.
At the end of the day, on any size of boat something can go wrong, and sometimes that thing going wrong is worse on a big boat and other times it's worse on a little boat.
If you spend your like mulling over all of the "things can could happen" you'll never go anywhere. In 40 years of sailing I've never had a furling system fail to the point where you have to drop/cut the sail off, but what I have had are a number of engine failures (which is a worse thing to have in a small boat), especially with outboards, and a skin fitting let go (again worse in a small boat), so it's horses for courses really.
You're probably right, I think I've just done too much "adventurous" sailing so I've seen quite a few of these failures first hand including a spinnaker parting in the middle and wrapping irretrievably around the forestay giving a quite large sail we had no control over! I guess normal sailing in normal conditions will rarely lead to such failures so one can work on the assumption all is well rather than the opposite which is how I now work :)
Searush
14 Oct 2006
- up to my neck in it.
back2bikes.org.uk
As a regular solo sailor (only coastal day trips) on a 30' ketch with all basic manual gear, I have to say that I wouldn't want bigger for several reasons;
Costs are manageable
Close quarters handling - I can push my boat off the quay if I get it wrong. It is easy to warp around in a marina in bad weather on my own.
I can handle the anchor on my own
With good timing I can even tack without winches if necessary
I don't need more space (even with extended family on board)
but each to their own, always good to hear of other's successes.
Carl s
31 Dec 2011
PVb I actually said that was when the problems start , a big boat is most def not easy too manover in marinas
maby
12 Jun 2009
A modern deep keeled boat with a bow thruster is reasonably easy well up into the forty foot range. I've seen large long keel boats reduce experienced sailors to tears!
