It isolates the DC negative. Never seen the point myself. I often convert it to an emergency start switch and re-label it.What is the purpose of this negative switch in a Princess V42?
Can you post some details of the marine standards that require boats to be built with DC negative switches please ?It depends on how the rest of the boat is wired, but isolating the negative supply can reduce the chance of stray current corrosion problems and fire. I would not change the manufacturer’s installation. .
It is not required by the ABYC, but is is compulsory for some other marine standards.
Commercial vessels in Australia, including yachts offered for charter, require a DC negative cut off switch.Can you post some details of the marine standards that require boats to be built with DC negative switches please ?
Without a negative cut off switch, all electrical devices have their negative supply permanently connected even if the circuit breaker or switch is turned off. The concern is if a high power circuit (with corresponding large cabling) creates a short circuit with a smaller diameter negative wire. The large fuse in the high power circuit is not always enough to protect the smaller diameter negative wire, which can overheat and cause a fire. Fortunately, this is not a common scenario, but isolating the negative supply has a benefit in reducing the fire risk and a larger benefit in reducing the chance of stray current corrosion.Could you also post some links to the boats that caught fire because they didn't have a negative isolator ?
Electrical problems cause a high percentage of boat fires, but the exact cause is not often made public. I am not sure I could even post links to fires that have been caused by more serious deficiencies such as a lack of fusing, even though we are agreed fuses are essential.
Many boats manage perfectly well without the means to isolate the negative supply, but having this option reduces the chance of stray current corrosion and fire. It is not something I would remove when the boatbuilder has already installed such a system.
But if the negative side is isolated through the switch, how can the positive complete the circuit ? Or am I answering a different question ?
Precisely. If the negative circuit is isolated then there is no possibility of a short circuit. However, the negative isolation switch will only provide this protection when the switch is in the off position (usually when leaving the boat, or if a fire is detected). Thus the reduction in fire risk, while useful is only small. The reduction in the risk of stray current corrosion from isolating the negative supply is arguably more significant.But if the negative side is isolated through the switch, how can the positive complete the circuit ? Or am I answering a different question ?
Many boats have "essential" circuits (such as bilge pumps, battery charger) left permanently on. These are not disconnected when the main battery switch is off.The point is once you have isolated one side of the battery, the other side is essentially inert. Isolating both sides adds nothing.
What a load of nonsense. You previously said the positive had to be a heavy wire. If the main positive isolator is off and there is, for instance, a bilge pump permanently live, it will be fused accordingly and if it were to come into contact with a negative the fuse would blow.Many boats have "essential" circuits (such as bilge pumps, battery charger) left permanently on. These are not disconnected when the main battery switch is off.
The positive wire from these circuits can form a short circuit with the negative wire of any other circuit on the boat (because none of the negative wires are turned-off even if the battery switch and circuit breakers are in the off position. A negative isolation switch removes much of this risk by disconnecting the negative supply for all the non essential circuits.
Paul, why do you think the boat manufacturers go to the cost and trouble of fitting these switches if there is no benefit?What a load of nonsense.
That begs the question "If there is absolutely no benefit then why did the regulatory body introduce the requirement".Presumably because there is some daft regulation in some part of the world and it is easier for the boat manufacturers to comply than argue why said regulation is stupid.
If you are disconnecting or bypassing these switches, especially in a professional capacity, you need a detailed understanding of the benefits and drawbacks of this action.
The truth is that there is a benefit; namely a reduced risk of fire and stray current corrosion.
It is perfectly valid to suggest that the reduction of these problems (especially the risk of fire) is only slight and that the extra cost and complexity of installing negative isolation is not justified, but it is important not to start removing or disabling these switches without understanding the pros and cons.
It was a requirement of ISO 10133 for a negative isolation switch to be fitted, in addition to a positive isolation switch in fully isolated 2 wire systems.
I do not know the reasoning behind that requirement and I do not know if it was carried forward into the new combined standard for DC and AC systems
I pointed out sometime ago that VP wiring schematics showed both switches for engines with isolated electrical systems but the observation was rubbished by P Rainbow
