[2574]
Do you prefer to use a masthead Tricolour or deck level Port/Starboard and stern lights when sailing at night? The below is from the RYA website:
"As well as the steering and sailing rules, the COLREGs dictate what day shapes and navigation lights a vessel must display to indicate its status to other vessels and when and what sound and light signals it must make. Yachts should note that although a tri-colour is permitted under the COLREGs (under 20m in length) using deck level port, starboard and stern lights in certain circumstances helps the officer of the watch on a larger vessel to identify you against background lights and establish the distance you are away from them more easily. Although the absence of a steaming light indicates that you are a sailing vessel, the COLREGs also have a provision for yachts to show an all round red over and all round green light at the top of the mast in conjunction with deck level port, starboard and stern lights. This instantly identifies you as a sailing yacht and your deck level lights remove the ambiguity a tri-colour can cause. "
It seems that the OOW much prefers deck level. With LED's now negating the power consumption issue it seems that deck level LED's is the way to go?
And does anybody have all round red over green at the masthead?
Rob
Rob
