Kukri
The following must be true - it comes from the Daily Mail!
Sarcasm again!
Red over green up the mast with sidelights is a good idea but a small boat the difficulty is getting the 1m vertical clearance between the all-round red and the all-round green.
It would require a change to the colregs to permit these two lights to be accommodated in a single fitting of reasonable dimensions. Maybe this has happened without me knowing.
My point exactly... The researchers said that being exposed to sarcasm required more ‘cognitive complexity’, or the ability to see things from more than one angle."
It's all to do with viewpoints and angles.During the Inquiry into the sinking of the Ouzo I believe it was mentioned that a navigation light at masthead level can look like a deck-level light at a greater distance when seen from up on the bridge of a ship.
With a rotating mast, a tricolour is out. I have an all-round white and TWO sets of low-level lights (10w for sailing, 25w for motoring and no need to go on deck in the event of a bulb failure). I would like to have red/green at the masthead which would require pairs of lights on opposite sides of the mast but I have yet to find red & green lights that cover 180°+, let alone LED types.
The green light fitting would need to be a strip of LEDs wrapped round the mast either side of the sail track. This ought to be visible from a distance 360deg even if the sail was obscuring part of it. A small series of powerful LEDs could be fitted into a hardened plastic fitting made in sections. I'm certain there are product engineers who could design one on the back of a fag packet in 5 minutes on this forum.
A separation between all round red over all round green is not required at the mast head is it?. 1m vertical separation is required between deck sidelights and masthead (steaming) light.
(i) When the Rules prescribe two or three lights to be carried in a vertical line, they shall be placed as follows:
(i) on a vessel of 20 metres in length or more such lights shall be spaced not less than 2 metres apart, and the lowest of these lights shall, except where a towing light is required, be placed at a height of not less then 4 metres above the hull;
(ii) on a vessel of less than 20 metres in length such lights shall be spaced not less than 1 metre apart and the lower of these lights shall, except where a towing light is required, be placed at a height of not less than 2 metres above the hull:.
Just don't have a stupid ensign on a stick obscuring the stern light.
That's my pet hate!
It was once pointed out that a tri-light on a yacht close to the observer, looks the same as a low level light on the horizon.
How does the watch know you are a yacht close to them with a light high up ? may be why all the ships are trying to hit you.
Brian
The vertical separation between the red at the top and the green under ought to be six feet.
