As promised an update on my problems associated with the close proximity of a Garmin GPS to a NASA VHF SX35 Radio. To recap, I'd positioned the two units closely together (GPS sat on top of radio) but the GPS signals disappear when the radio is switched on (not transmitting, just receiving).
Placing an earthed metal plate between the units (as suggested by one reader) did have a marginal effect but not nearly as good as providing an external GPS antenna placed some distance away from the radio! This was proved by carefully moving the external antenna (a puck type) increasingly nearer or further away from the radio whilst still keeping the hand held GPS in close proximity to the radio. Within about a metre the GPS signals started to show a collapse.
So to retain a hand held GPS in close proximity to the NASA SX 35 so that it (the GPS) remains fully functional you need to supply the GPS with an external antenna which is sited at least a metre away and in my experiments, using a Garmin GPS 76 with a puck antenna full signal strength was obtained and guaranteed with the antenna at about 2 metres distance.
To the respondants of my previous query on this problem, my sincere thanks. If anybody is thinking about installing a similar setup/combination then experiment first before deciding a permanent fix. Make sure your hand held GPS is able to take an external antenna and then site it a good 2 metres away from the radio if your radio is an SX35.
I have now purchased a new Garmin GPS 76 to replace my Garmin GPS 12 which doesn't have an external antenna capability. (Anyone want a GPS12?)
NASA do not warn of this problem, so if like me you have a small boat and you want to use your existing hand held GPS in close proximity due to space resrictions of a small boat.......be warned.
Happy and safe boating to all.
<hr width=100% size=1>An Ron Beag
