Bigplumbs
Don't think anyone mentioned it yet. but the most annoying thing you will find with a boat like this on the river, is that it won't track straight.
You will find initially that you are snaking along, going left and right as you try to correct the direction of the boat. And you might well think something is wrong.
This is usual, and with practice you will find that you are over compensating your steering corrections, and in time find you will need a lot less input to the steering than you initially thought.
Just a heads up for your first outing![]()
It is because you are at low speed in a boat that is designed to go fast and it has no rudder. This happens on all outdrive boats. There are things you can buy to fix to the leg that will help but on my Sealine S24 on the broads I just learnt to live with it. Interestingly if you are heading into the tide or flow it is not so bad. Fact of life and very odd at first but ok once you suss it. This does not seem to happen with outboard motors so bad
