vas
me again...
had a bit more time this evening so took onboard JFMs suggestion on shifting back the HT, and trying to keep a cleaner side elevation and came up with the following. Again only one tube outside following the salon window slanting further back, this way I have split the HT into three equal portions, the cantiliver at the front being one third of the whole length (OK almost, I'm working on PhotoShop on that so don't expect great accuracy...)
Made more accurate measurements, only need this HT 2.4m long at the most. I think it fits better on the whole Mystere design lines.
There is the option of keeping the stbrd side aft tube short by mounting it on top of the 600X600 box (where again on port side the forward facing tube is mounted), but the port one will have to go all the way down to superstructure. On the plus side I can avoid fitting handrails on port side with this tube in place
Probably wont avoid fitting rails on top of the side helm windows though.
Hopefully I'll be on board tomorrow and check mounting points, necessary padding and cable routes. Started working on the mounting details, will post some sketches when they start making sense
cheers
V.
cheers
V.
