monticello1957
New Member
Hi Vas, hope you still are reading replies to your thread. I am planning to build-in a bowthruster in a wooden boat 57 feet..In have several questions hope you can help me out. First if I look at the pictures after laminating the tube on the outside of the hull...did you just fill it with epoxy putty? And I can see the layer of the matting on the putty bud not on the hull nor into the tube. You did not laminate with the glassfibermatts the tube to the hull?
Further on the inside, the system how you cut-out the three layer is clear bud...did you laminate each layer separatly or as on piece?
How is the tunnel holding? Have there been any problems since you went into the water...leaking, cracking? would you change anything would you do the work allover?
Have you ever heard that the tunnel should be installed into one of the frames instead of between frames as you've did?
Thanks and kind regards,Patrick
