freddyuk
Here are some images of my heater system installation and my hot/cold deck shower where you can actually stand up (unless you are 6'+)
The diesel heater is bolted to the transom behind the rudder stock using the existing swim platform bolts and some stainless solar roof brackets I had lying around. The diesel supply will be T'd into the main tank using some copper tubing (I used the plastic pipe for testing). The exhaust is bandaged and secured to the same row of bolts with stand off brackets going up to the outlet on rear corner. The tiller is secured above here to get it out of the way. There is a smoke alarm inside the lazerette and an auto fire extinguisher.
The heater outlet splits with one pipe going up inside the rear transom space then through the storage bin and into the shielded outlet butterfly vent. With the covers on this keeps the rear deck toasty but can be turned off and the rain hood keeps it dry. The main outlet is fed via insulated 4" hose round behind the fuel tank and along under the saloon floor where it splits with one outlet up inside the front seat storage bin and out under the saloon table. The other outlet continues into the front cabin. In order to get the large diameter heater duct out from the lazerette you have to cut a round hole in the bulkhead behind the fuel tank. The only way to do this is to remove the house battery and feed yourself feet first forward into the hole under the saloon table and get your head down towards the stern with drill and cutter in hand. If you are claustrophobic DO NOT TRY THIS. You will not be able to quickly exit from this position. The heater pump can be heard inside the boat as a very faint tapping and this comes via the holes in the rear bulkhead so sealing these would eliminate any noise.
The inverter is housed on a fireproof board in the battery void. Input DC power is fed up into the saloon to a recessed isolator switch (via inline fuse). The AC power is fed via a 4 pole transfer switch from the AC breaker box - or the inverter - to the sockets.
The solar input keeps the battery topped up and feeds the low voltage supplies to the diesel heater, Netgear Aircard hotspot, USB charging socket and the backup engine temperature gauge.
The rear deck shower is plumbed into the hot and cold supplies in the lazerette and fed up inside the starboard void. There is a mixer tap unit below and a rubber covered access point above for the shower hose. I need to fit the gasket to the hose to keep the water out of the hole. The stainless shower hose is not good enough for saltwater so needs replacing but it does need to be flexible to work well.
With the covers on you can shower in comfort.
The boat is a mess as I have been laid up with a slipped disc since August so sorry about that. A few things to finish still as is the way.
