shetland536
serial number 9427136
working fine last year but not flushed out after use,has been sat in the garage since,now it will not move.
i can go in and out of gear ok and the prop is free in neutral.
i dont want to throw a lot of money at it so if i cant fix it cheaply i may sell it as spares or repair instead.
is there a common part that seizes in engines?
should i take the leg off and see if the engine will turn then?
i dont want to buy a manual just to find out i need to spend £200 on bits.
any advice?
i`ve had the plugs off and soaked the bores with wd 40 and left them for the last 2 weeks.
i only ran it for 5 minutes last year so could it be seized from not being used?
any advice?
