casper10
I have a merc 60 hp with water pumping problems. Basically the water is not reaching the tittle tattle outlet. It is coming out of a small hole inside the leg housing near the exhaust. At first I thought I had blown a hole in the engine but i have my old Mercuy engine and this hole is present here also it is about the size of a pencil. If i jet water up the water pipe it will come out of the tittle tattle pipe where it should do but also still out of the hole in the leg housing,. If I jet water (but not much pressure) it will only come out of the leg housing hole. The impellor is 100% ok, i have been checking it regular while trying to sort this engine out. There is nothing in my manual about water coming out of this hole in the leg housing (does anyone know what it is called and why it is there?)
I am guessing that I have a blockage in the engine waterways ( i have taken off one of the plates to the engine that exposes 1 side of the engine waterways and this is all clear) If it is a blockage is there anyway of dissolving what may be there ?
Any help would be greatlly appreciated.
Many thanks
Trevor
Many thanks
Trevor
