Measuring Cocks
lustyd
27 Jul 2010
Hi all, any advice on how best to measure through hulls and seacocks in situ? I need to buy the parts before lift out just in case there’s a shortage again but can’t see anything obvious marking on them and obviously can’t measure internal diameter while afloat. I’m not comfortable removing the hoses while afloat, hence replacing them at lift out
VicS
13 Jul 2002
Using ordinary calipers (digital if you must) measure the OD of the threaded part of the through hull/skin fitting.
Look up the BSP size that corresponds to that measurement in your copy of Zeus or on line thread tables.
That's the size you will need
Also measure the OD of the hose tail to determine the size of the hose tail you will need.
Tranona
10 Nov 2007
The inlet for the loo will be 3/4" BSP, the outlet 1 1/2" BSP. Engine intake almost certainly 3/4" BSP. sink and shower outlets 3/4" BSP (or maybe 1/2" for sink - easy to tell the difference). DZR will be physically direct replacement but TruDesign although same diameter and thread sizes have physically different size bodies which may cause space problems.
Buy complete sets - skin fittings, valve and hose tail, then just cut off the outer flange and pull the comlete assembly from onside the boat. Their is no shortage of DZR at the moment but don't know about TruDesign
lustyd
27 Jul 2010
Thanks chaps. Yes it’ll all be TruDesign, no point messing about with metal ones in this day and age. They’ve been hard to get for a while so just making sure I have them ahead of time as we’ll lift out March or April. Also an element of heading off inflation, the way things are going the money will be worthless this time next year and the cocks may cost thousands ?
Our boat came out of the factory with 1" BSP skin fittings for both the galley and heads sinks. I know this because I replaced them with DZR after we bought her.
I strongly suggest you measure, as described by VicS, rather than relying on "it will be..."
Tranona
10 Nov 2007
The toilet outlet might also be 1 1/4 BSP. (The 32mm bore corresponds well with the typical ID of a hose tail suitable for the 38mm sanitary hose).
It is on a Jeanneau which is 1 1/2" for the toilet and 3/4" for the others. 1" is unusual on modern production boats - but I could always be wrong, and easy to check.
Plum
6 Jun 2001
UK East Coast
I did not expect Jeanneau to be different from Beneteau which, in my experience, have been 1 1/4" BSP seacock with a 1 1/2" OD hose tail for the heads waste.
www.solocoastalsailing.co.uk
Juan Twothree
24 Aug 2010
I know nothing about the question you're asking, but I just popped by to say well done for the subject title.
Totally aligns with my sense of humour.
Daydream believer
6 Oct 2012
Southminster, essex
I did not expect Jeanneau to be different from Beneteau which, in my experience, have been 1 1/4" BSP seacock with a 1 1/2" OD hose tail.
Which backs up a female friend of mine who said that they are often smaller than originally claimed.:(
My german ones are of the larger variety. ? But one should always check before the job is attempted.;)
starfire
7 May 2005
Not In the Med
Measure in inches & add 1/4" for the thread size
wingcommander
25 Jul 2013
On leaving the boat today swmbo commented on how stiff the heads cock was ........to operate. Was about to reply the more she agitated it , it would eventually lose its stiffness . However she's a sharp minded lass , and would have hit me with a .....oohhhh it come off in my hand.
RJJ
14 Aug 2009
Just cut it off.
