ashtead
Indeed just plug in or buy a portable one etc.
The minipresso I linked uses the same capsules so we have that for when there’s no power and the nespresso machine for when there is. Wacaco also do minipresso machines for ground coffeeI have to admit that I am considering checking the power reqt's of my Coffee maker ... a suitable inverter may allow its use (sailboat) ...
Have you considered that it may be time to reef?I’m not the world’s most ardent fan of gimballed stoves.
On the one tack its way out there and swinging away above you.
And on the other you’re pressed up against the crash bar trying not to bend over it as stuff bubble and steam below you.. Hey ho. Me fussy?
Move up from your monomaran and you don't have these problemsCoat hangers were the Make Do alternative to chain ..
Put the stove on or n near the centreline and low down at the boats longitudinal axis of roll, so I can sit and cook, and enjoy that lovely Italian mocha, whatever the weather..
The real solution is obvious to Neeves and I.Have you considered that it may be time to reef?
That’s exactly what we do. Stainless double walled cafetière.or ‘French press’ as the Americans call it.We have a stainless steel double wall french press. Boil the kettle, turn off. Warm the pot with a swill out of boiling water, put the coffee in, chuck the water in, lid on, place pot in the ‘downhill’ (ie not very downhill) corner of the cockpit to brew for a few mins or until an opportune moment to pour. We have not yet known the kettle to leave to stove, not even beating out of the Needles fairway with a Spring ebb under us. The kettle lives on the stove semi permanently. The galley is pretty much at the pitch pivot point, very handy.
We use one at home too, it keeps the coffee warm in our Victorian cold store masquerading as a house.That’s exactly what we do. Stainless double walled cafetière.or ‘French press’ as the Americans call it.
Just do not overfill it with water, the pot will not fall with heeling but a lot of coffee could spill
True. Also the less water you put the more Italian the coffee gets. An Italian told me.Just do not overfill it with water, the pot will not fall with heeling but a lot of coffee could spill![]()
Unless, of course, you prefer nescafe. Subjective.....and it sells masses.You cant make a decent cup of Nescafe, pretty much by definition.
If I was in that much of a rush I'd go by plane....Move up from your monomaran and you don't have these problems
We do use non slip mats and making double digit speeds, fresh coffee, toast made from freshly baked bread with decent homemade bitter marmalade - sea temps of 24 deg - what more do you needat 8am.
Jonathan
Alas, the only time I have felt nauseous at sea in the past 25 years was when we all borrowed a 38 catamaran and played with it up down and around a Caribbean island.The real solution is obvious to Neeves and I.
Yes, question of personal taste of course.True. Also the less water you put the more Italian the coffee gets. An Italian told me.
That's probably why I don't like the stuff that coffee shops sell!I know it’s an old discussion but Nescafe is not coffee
How big was the boat?Very true. He even made the chain himself whereas I bought it. But what about winching without winches?
