rogerthebodger
That’s what I dream about
What type of cooker do you have as there is possible to make or buy a gimble and /or pan clamps
Can’t happen with the chainExcept as it fills, the espresso pot becomes top-heavy and gimbals aren't enough.
I speak from experience. Or should that be esperience?![]()
No flame-failure devices. Use with care.It looks antique and is called Vanette S2. It’s a bulky unit and there is no space to gimbal it. Chain and hook works as pan clamps. I guess if I ever cross an ocean it might be wise to invest in a new cooker. And so many other things!
The technical term is over extraction according to google!I prefer to make coffee with water that is not boiling but around 90ç.
Those Italian coffee makers as in the pic, and the percolators use repeated boiling water, which is the death of good coffee.
You cant make a decent cup of Nescafe, pretty much by definition.When on relatively long trips in our semi-D flybridge cruiser (usually around 100 miles so not exactly ocean crossing) in bad weather we used to make coffee straight out of the hot which was near enough to boiling to make a decent cup of Nescafe.
Also gratuitiously provided with superfluous impossible to clean corners. Offensive Italian form-over-function designI prefer to make coffee with water that is not boiling but around 90ç.
We also don't carry instant but do grind beans (and drink the coffee without milk or sugar).We don’t grind beans on board, but don’t carry instant ‘coffee’.
Sugar in your coffee is for builders and children.Coffee, the new anchor.
Jonathan
Forget the hob -just use capsules in the nexpresso if you like variety in your coffeeno need to use the nasty gas then in that elderly hob with any associated safety worries.
