howardclark
Just a damp cloth to wipe it off, dead easy, dries white but can be stained-I've never had to stain it because clean up is so good, just like Titebond 1 & 2
Here's my teak-faced ply table with a teak fiddle rail (both from Howells in Poole).
Too thin because it flexes. I have it fitted with two slide-in wall fixings and a central leg. Even a slight lean on the corners made it flex. I simply made up another sheet of 9mm exactly the same size but about 20-30mm in from the top edge, as by then I had made the fiddles and was rather proud of the finish. This gives rigidity but you don't see the bulk, plus there is more for the fittings to screw into. Yes it is about twice a heavy as a result, but I don't move it much.
