doug748
Here is an affordable Gibsea:
http://www.harbouryachts.co.uk/boat.php?stock_id=SEKP 1306&boat=Gib'sea-30
That looks pretty!Here is an affordable Gibsea:
Don't be surprised if it's not what you're expecting, be pleasantly surprised if it is. There are lots of owners who are frankly deluded if they really think they're going to get close to what they're asking. I've been to see dozens of boats & most are a disappointment but it's wonderful when you come across a properly looked after boat. If it's a Sadler 32 you want & there's loads for sale go & see them all & I wouldn't worry unduly about whether you might miss one if you carry on looking. That's pretty unlikely unless it's truly exceptional & from what you've said I doubt this one's going to be...
A two-owner Sadler 32 with minor issues for circa £12,500? Based on your spec for a first boat, I'd say this is pretty good - and, being sizeable enough, you might well keep it longer than just a couple of years!
Consolidate your offer - subject to survey and get him to ask the yard to quote for drawing the prop-shaft and dealing with the issue (stern-gland? cutlass-bearing?); whatever it is, it isn't going to be hideous and your offer should reflect this. I wouldn't worry too much about the minor items like the Eber heating or the windspeed thingy.
Haha, that made me laugh a lot! I'll send you a PM in a sec with the link. It's being sold privately though. It's a one owner Sadler.A two-owner Sadler 32 with minor issues for circa £12,500? Based on your spec for a first boat, I'd say this is pretty good - and, being sizeable enough, you might well keep it longer than just a couple of years.
Consolidate your offer - subject to survey and get him to ask the yard to quote for drawing the prop-shaft and dealing with the issue (stern-gland? cutlass-bearing?); whatever it is, it isn't going to be hideous and your offer can reflect this - split the difference? I wouldn't worry too much about the minor items like the Eber heating or the windspeed thingy. Get a boat that's good to go and deal with the little things over time.
At the end of the day, you'll know when you've found the right boat... or you'll know after you've turned it down to go look at others and find it sold when you go back!
EDIT: I'm not in the market for a Sadler, so PM me with a link to the broker's site if you want, and I'll be happy to give you a slightly more informed gut-reaction.
Hi Alex,
Pleased it was better than expected. Do you know the age of standing rigging? I wouldn't worry at all about the NASA Clipper Windspeed/Direction, maybe remove it & sell it on ebay for spares unless it's an obvious fix. Their masthead units are a bit renowned for being problematic. Install a Windex instead if there isn't one already would be my suggestion. I'm not sure how much attention would be paid to the prop shaft by a surveyor, they don't look beyond the very obvious with the engine, e.g. & they'd only check if it's easily accessible which is unlikely. It may be that there's too much play in the cutless bearing causing some vibration, you can check this yourself by gripping the propeller & seeing if the shaft moves within the bearing. Surveyor should also check this, ask for recommendations for a surveyor on here if you plan to use one. There really should be no appreciable play but a little bit is quite common. You could maybe also get a straight edge & check that the shaft is straight & true. It's probably unlikely that a whole new propshaft would be required.
Eberspacher's often seem not to be working on boats, I've had one & personally don't like them. I found it expensive to run, noisy, needed more electrical power to run than you might think which kind of defeated the object of a heating system for use without shore power & parts are very expensive. The one I had didn't like to be run for extended periods on low heat setting, it coked up badly but then I was living aboard through the winter. For occasional use I think they're OK but very expensive kit. Other people rave about them though, only my opinion...
Totally agree...
That's really encouraging so far.
On the propshaft, did you grab it and give it a rattle? Would it turn by hand?
Of the things you've mentioned, that could be the only thing of real concern, others you can deal with in slower time or just do without.
Is a whole new propshaft expensive to put in? What sort of figures would it run, 300-500, thousands?Funny noise...
Could be, as you've been told, the cutlass bearing inside the p bracket. Relatively easy job, but sometimes, like when I replaced mine, it's the propshaft itself which has taken most of the wear and turns out to need replacing as well. The whole assembly needs to be removed anyway to get at the bearing, so no extra yard labour, just a delay whilst a propshaft is made up to the same pattern as the old. Whilst everything's out, you may find you ought to service/replace the propshaft seal that keeps the water out. Again, not much extra bother, just the cost of the bits.
The other possibilities that occur to me are either that the folding propeller is worn and rattly, and that could be expensive to replace, or that the p bracket itself is a bit loose and needs fixing, this is a yard job and could cost a bit. But no reason to worry about either of these for now, such faults would be obvious when you have the survey and you'd want to get the cost of the work knocked off the price.
Do let us know how you get on, the boat sounds exceptional for the price, and if you are really keen, then an offer subject to survey is the next step.
It has been ashore since October, so it can only be rain water or water from where he has been cleaning it (possibly).Just spotted your remark about water in the bilges. That's something I'd want to check out. If rainwater has been getting in, you want to know how, and what route it's taken, because there's the potential for some serious damage.
On my Sadler, the bilge under the engine can get water into it via the locker lid underfoot. I wouldn't worry about that, just a question of improving the seals. However on mine, this bilge does not drain into the others under the saloon sole, so if there was water in these, it's got in some other way.
Both the Son's sailed the boat and still did up until recently, but the one showing me around said that he has other hobbies and things to do nowadays and his brother is often travelling out of the country and doesnt get the time.So, woman in her 50's bought the Boat Show boat then had it professionally-maintained for the next 35 years before she got too old to sail, and her non-sailing son is selling. On the surface of things, this sounds very positive - so long as the boat hasn't been unmaintained/neglected in the last year or so - but even that isn't a deal-sinker.
I can't comment on the water in the bilge, but this could have a completely innocuous cause. You'd need to speak to other Sadler 32 owners (see their association website?) on this and any other Sadler-specific issues.
I'm sure the seller would like more than the £12.5k he remembers someone 'offering' (even if he can't remember that it was you), so its a question of sharpening your pencil and making his a firm offer subject to survey and prop-shaft/bearing/etc being resolved at shared cost (or his cost entirely?).
If he decides to accept your improved offer (and a quick internet search shows a lot of older Sadler 32s for sale in a generally depressed old-boat market and in the middle of freezing weather, so this might focus his mind), then arrange for an immediate out-of-water survey (I assume she's out the water?).
An excellent and thorough surveyor, who I've used myself, is Chrissie of this parish, who'll want to look at everything:
Chrissie Davies
Endeavour Yacht Surveyors Ltd
Gosport
James_Calvert has worried me about the water leaks/dampness now :-(
Check water filler and plumbing to and around water tanks under starboard berth for source of water in bilge.
£12.5K for Sadler 32 makes me feel near suicidal as a relatively recent owner!
Chrissie Davies
Gosport
