Obi
Sorry if this a little long winded...
I decided to have a little play with going astern yesterday after leaving my berth for a single handed sail. In the confines of the marina it was tricky, neighbours must have looked on in glee/horror depending on how close they were to me. So I made my departure resolving to have a go in the open space of the Solent.
I have a 85hp Perkins (or is it 80hp), and a three blade prop, significant prop walk to port.
My helm is generally quite heavy under engine with the prop washing over the rudder. But going astern at about 3-4-5 knots I could eventually get a straight line, and even turn to starboard.
Do any of you experience the same characteristics, I knew she would be hard work. Has anyone found a way to work around this? Can we exist only going forward in the UK, Europe and the Med, apart from when leaving a berth?
Having now moved berths where previously when going astern to leave my birth the prop walk lined me up nicely for leaving the fairway going forwards, and coming in momentum and prop walk worked in my favour to get my into my berth. However, I now have to come out of my berth, the stern pulls to port, then I go forwards hard to starboard, and spin 180' using prop walk to pull the stern to port, and then helm forwards to s/b. This was fine until I was being blown off in only about 10 kts of wind pushing me to starboard, I got part way round, abeam to the wind, and then the bows went off down fairway and I drifted about 4 berths down the fairway before managing to get 180' round to come out forwards. Thankfully there was room to drift! perhaps I should have gone forwards to starboard a lot harder?
Bearing this in mind, upon my return I opted to not employ my usual tactic of passing my berth by 3 or 4 lengths, and spinning through 180' and coming back at it facing towards the finger. This tactic means that i can get the momentum of the yacht turning into the berth to take me towards the finger rather than coming the other way and momentum taking me "off" the berth towards my neighbour. Had I been confident to pass by, spin the 180' then return it would have been less of a debacle, but I didnt fancy trying my luck after the morning :-(
I knew she would be hard work, but I thought I would learn to handle it more quickly. Has anyone found a way to get cope with this kind of characteristic admirably?
Can we exist only going forward in the UK, Europe and the Med, apart from when leaving a berth? I am/want to do a lot of single handed, maybe this is where the plan falls down. I dont have the pennies for a bow thruster and thought that I could learn the skills to manage without one, Ive never used one on any yacht, and always managed ok with a fin keel, even with 3 blade props.
I may have stuck my neck too far above the parapet by admitting all of this, but hopefully something constructive may come out of this thread that helps me and any others going through this.
Thanks in advance.
Mark
Thanks in advance.
Mark
