Snowgoose-1
Easy to find live tide levels but can't find live tide speed.
Diamonds are ok but wondering if any folks know of any live sites.
TIA
TIA
‘Faster than I could swim with fins’ I can report, from just East of Yarmouth pier at 0800 on Saturday. I’d be fascinated by such data if it exists.Easy to find live tide levels but can't find live tide speed.
TIA
Can understand that.‘Faster than I could swim with fins’ I can report, from just East of Yarmouth pier at 0800 on Saturday. I’d be fascinated by such data if it exists.
Do the plotter based (almanac derived) streams take into effect coefficient? Keep meaning to check whether they are just based on mean or are biased by the coefficient.Dunno about sites. I just bring it up on my plotter.
In practice, I find it rather clonky, but it gives a reasonable indication of direction and roughly what sort of strength. I haven’t checked but I imagine that the coefficient is taken into account. For critical situations I have always used the diamonds on Admiralty charts, often easier than tidal atlases. I’m sure that much more information is available nowadays, with less need for interpolation.Do the plotter based (almanac derived) streams take into effect coefficient? Keep meaning to check whether they are just based on mean or are biased by the coefficient.
I know someone who was involve with chucking buoys in the ocean and tracking them by satellite, also devices which sink to various depths to monitor currents, measure temperatures and amuse the fish.It's not a trivial thing to measure meaningfully. The further your sensor is from any fixed object, in order to be in clear and smooth flow, the more difficult it is to connect and ensure its safety!
Normally I go in at LWS, slack tide, but still with a line to grab, tied to the boat. I’ll be doing it again soon, one of our XODs hit Harrys Rock, needs it’s keel looking at.Can understand that.
The late John Goode of PBO berthing series , stated that one knot of tide is equal to a F4 wind. Not quite sure how one arrives at that figure but I believe him when trying to swim against the tide.
It must depend on the cross section of your vessel (both above and below the water). Probably can be calculated by some fluid dynamics - but if your vessel is adrift, with zero wind with a 1 knot tidal stream the boat moves at 1 knot in the direction of the tide. John's rule of thumb implies that if there is no tide running but F4 wind and no sails up you will drift at 1 knot with the wind. Presumably if you find yourself with F4 wind against 1 knot tide, they effectively cancel each other out.Can understand that.
It's not the boat, it's the surface water movement.It must depend on the cross section of your vessel (both above and below the water). Probably can be calculated by some fluid dynamics - but if your vessel is adrift, with zero wind with a 1 knot tidal stream the boat moves at 1 knot in the direction of the tide. John's rule of thumb implies that if there is no tide running but F4 wind and no sails up you will drift at 1 knot with the wind. Presumably if you find yourself with F4 wind against 1 knot tide, they effectively cancel each other out.
am i being a bit dense - what is the surface water movement? is the suggestion the air blowing across the surface of the water at F4 creates drag on the water surface (which it will) moves the surface (how deep?) at 1 knot? Does a boat a drift in that sea then move faster than that (because it has its own cross section to catch the wind) or slower (because it has a keel below the surface creating a resistance to drift)? I don't recall John's article but he was generally quite pragmatic - so knowing the effect on the surface of the water, whilst interesting, seems less useful than knowing how a wind/current compare on a boat - particularly if trying to get it in a tight space.It's not the boat, it's the surface water movement.
Surface water flow is generally accepted as the top layer that vessels operate in. There are various components to this and around the UK, the major cause is of course, tide. Tide streams are given as surface water flow. JG suggestio. Is that wind adds or subtracts to this with a vector depending on direction.am i being a bit dense - what is the surface water movement? is the suggestion the air blowing across the surface of the water at F4 creates drag on the water surface (which it will) moves the surface (how deep?) at 1 knot? Does a boat a drift in that sea then move faster than that (because it has its own cross section to catch the wind) or slower (because it has a keel below the surface creating a resistance to drift)? I don't recall John's article but he was generally quite pragmatic - so knowing the effect on the surface of the water, whilst interesting, seems less useful than knowing how a wind/current compare on a boat - particularly if trying to get it in a tight space.
There is a lot of hardware out there already, giving wave data and tidal heights..In order to give live tidal streams you need to deploy current meters with a live data feed. That's a lot of hardware to source and maintain to meet the OP's requirements.....
Yes, but I don't know how much finds its way to UKHO as there are also concerns about commercial confidentiality. The data belongs to the businesses that pay for it. However, its many years since I did any hydrographic work as I moved on into education and retired a while back.The velocity will have been measured accurately for wind farm foundation loading and scouring management, so lots of data will have been collected, but real time, not aware of any beyond heights, as already stated by others.
Anemometers connected to the web are pretty common place..
