oldgit
Have two 105Ah wet batteries of indeterminate make failing miserbly to provide sufficient power for any length of time due to amount of stuff needing power.
They test as being OK but are 3 years old, had a hard life and suspect too frequently having been run down close to their ruin forever voltage .
Plan to replace both.
Ideally this time want max amp hours batteries but with width and length 345mm x 190 mm the same to fit in existing battery box.
Want to stick with wet due to not being sure that all charging systems (shore /genny/ alternators can cope with any other type plus cost of alternative types of battery.
STD Terminal location at either end of battery please.
Height no problems.
Can I fit a pair of these (or similar) without grief . ?
2 x 150AH LEISURE / SOLAR / OFF GRID / WIND TURBINE BATTERIES 3 Year Waranty | eBay
Yuasa available at similar price.
All comments welcome,
Height no problems.
