The usual flouro light fitting has a switching power converter to bring 12v up to several hundered for running the flouro. Surely you have to disconnect and bypass this power converter so 12v goes direct to the tube. This seems like a great idea to use the fitting especially when most failures of flouros are in the power converter. I am confused because no one has mentioned the modifications needed in the fitting. olewill
I wouldn't be put off because early lopolights were a bit troublesome. After a recommendation of a forumite I fitted three of these:-
http://www.nasamarine.com/proddetail.php?prod=EasyLightled light bulbs
I am pleased with the performance. If LEDs are driven with the correct current and kept reasonably cool they should have a very long life.
If you look at some of the street video displays they contain literaly millions of 5mm LEDs. They work 24/7 and rarely show signs of individual LED failures.
Thanks for the replies. I have bought from Bedazzled before and also have been very pleased. A little steep on the pocket perhaps (hence the question) but good quality I'd hope.
