saltyrob
Hi Folks,
I have fitted an Exide ET 650 flooded lead leisure battery which receives a charge via a 100 w solar panel and Victron SmartsSolar MPPT 75/10 solar charger. The charger allows the absorption and float rates to be adjusted to suit the battery. The charger factory default for the float charge was 13.8 v which I read somewhere was a little on the high side so have adjusted it to 13.4 v, to reduce the risk of overcharging. I cannot find any manufacturers info re suitable charging rates . I would be grateful for any can advice on this matter.
Also just out of interest , if a battery is disconnected and , 'rested', for a day or two f will it have a slightly larger voltage then when connected up even if no current is being drawn.
Many thanks
Rob
Many thanks
Rob
