geem
8n summary, compression is now not a necessity but for all practical, purposes, you still need to do it to restrain the cells so they can be secured in a boat.I also think that over the last year a lot of the initial stuff like which buss bars to use, compression or not, top and bottom balancing is getting clearer and many of these appear not as important as initially suggested.
Top balancing is not an issue if you use grade A cells and a bms with an active balancer.
Busbars are easily made from copper bar. I just drilled mine and tapped to M8. There is no need to buy an expensive Victron Lynx system.
Cost of cells has dropped about 40% in 12 months.. NH00 fuses, one per battery, provide a good economic solution to fusing.
