alant
Generally speaking private moorings will have pickup buoys so the lassoing method won't come into it for most of us.
Seriously though, if a standard method of making initial contact is damaging buoys then there are two things that need to happen
1 the rya need to TEACH crews that it's not always the right way.
2 the people who make mooring buoys need to consider lassoing and ways of preventing damage from this technique.
For now - if you have such a buoy then please mark it clearly with "no lassoing" then at least there is no excuse. I would also suggest that you change it for one that can be lassoed next time it gets changed.
Lassoing - should not be used if there is a pick up buoy, because the pick up line will often get entangled & wrapped around the mooring chain, by the lasso, rendering it unable to be used by the next boat.
Pick up buoys - how many people go for that (expecting it to hold the boathook/crew/'heavy' boat) instead of the line underneath it? These small plastic buoys, have been sunbathing since originally attached & often very weak/brittle due to UV.
