lassoong buoys
Robin
30 May 2001
high and dry on north island
Have any of those who condemn the process ever asked the RYA why they allow sailing schools to teach this method. If it is as potentialy damaging as claimed then I would have thought those with the knowledge should have already informed the RYA, at first sight it seems they haven't.
Why? I don't care really as long as the method isn't used on my buoy! I would be less bothered also if it was merely a temporary thing for use by the less competent before attaching a line properly but I have seen boats overnighting whilst hanging on a lassoed buoy and in windy conditions.
Elessar
10 Jul 2003
River Hamble
The pull is directly trying to separate the inflated part of the buoy from the riser. The only function of the bladder is to make the top of the riser float. A pickup line puts the strain directly to the riser.
Sorry SL, you are wrong.
The force from the rope, whether shackled onto the riser or just lassood, is horizontal. There is no sliding up force.
The force on the buoy is thus the same whether it's a pick up buoy or a lasso.
See below
Vara
20 Feb 2004
Canterbury/Dover
No wouldn't do that, lassoo only for initial contact, then secure properly.
25 Feb 2010
Yes the riser carries on as a tail for a couple of feet past the shackle on the buoy.
I shackled the new strop (white nylon) to the buoy shackle and the second strop (the yellowish line) to the end of the riser tail. That way if the shackle on the buoy lets go there is still a strop attached to the riser.
The lilac and yellow line is the lasso. It's an old halyard with a loop at the end with the line passed through itself to create a slip loop.
Cheers.
I must admit that I don't like unbuoyed strops. I much prefer pick up buoy and chain...mainly because that's what I'm used to.
It hadn't occured to me to use a proper lassoo with slip knot etc. When I "lassoo" I just throw a bight of rope over the buoy, holding both ends. That's what I was taught to do.
I think I'll play around with your method next season.
Pagetslady
15 Feb 2006
Fleetwood marina
Cheers.
How do you remove the lasso if it has a slip knot in it surely the best way is to hold both ends of the line and toss the rest over the buoy.
Mike
maxi77
11 Nov 2007
Kingdom of Fife
Now how do you expect people to know not to use the technique on your buoy then. You almost provoke me into making an uncharitable comment.
25 Feb 2010
See below
Sorry, but I'm not convinced by that at all.
I'm much more convinced by the stories of damaged buoys that others have reported.
Elessar
10 Jul 2003
River Hamble
I'm not.
The link you pasted to a buoy that is vulnerable said it needed a pick up buoy.
I don't see how it puts more force on a buoy than a pick up line - ie I don't believe the damage reports.
Most people here lasoo and it seems have done so for years. I'm glad about that because it is the safest way of securing to a buoy - temporarily.
I will continue to lasso buoys. I'm glad I'm not alone. If vara has been doing it since 1973 then that's good enough for me.
For those who think it demonstrates my lack of skill - good. I don't care what they think of my skill level.
I will particularly look for snow leopards as he says
"If I see you doing it to mine you'll be left in no doubt of my feelings on the matter."
As ranty men always make me laugh :D
SAWDOC
24 Feb 2008
Ireland West Coast
If what you are saying is that you are going to moor up using your chosen method, no matter what damage may be caused to the mooring, then I cannot agree at all.
There are thousands of these buoys around our coast and to dismiss them as being "not fit for purpose" is a little OTT. Forumites have already indicated that there have been problems in their moorings as a result of lassoing and surely we should learn from this?
There are different methods of picking up a mooring.....using a boat hook, lassoing, sometimes just leaning down and putting a line through a buoy, using a tender etc etc. Surely the seamnalike thing to do is to use the approriate method not to always do it one particular way and ignore other techniques?
Well done on hopefully steering this interesting thread in a suitable constructive direction.
I use neither boat hook nor lassoo. Because of our high free board, particularly at the bow, I am more inclined to bring a line aft from the mooring cleat on the bow and grab the ring on the mooring buoy from the helm position and thread the line through. I then walk forward and secure the free end of the line at the bow. Seems to work well so far.
robmcg
17 Sep 2006
In exile in Scotland
I'm not.
Believe me these moorings do get damaged by lassoing. Unless you are in a dire emergency, I just cant see use of a lasso is justified. Picking up a buoy isn't rocket science, even when windy or a tide running.
Robin
30 May 2001
You can make whatever comment you like, charitable or not as this is a place to express an opinion. I don't have a buoy any more, haven't had one for many years as until our last boat was sold we kept her in a marina berth and our current boat is in Florida nowhere near a buoy.
I don't see it as my responsibility at all to try and educate the RYA but I do think I can be free to comment as I did here by saying that I personally don't like it, other than as a very temporary measure when more normal tactics are not working.
Lakesailor
15 Feb 2005
Near Here
Mike
Yes. To be more precise the reason I used a slip loop was to capture the buoy so I could haul it onboard. There is no top loop on the buoy. Then I could replace the strops in comfort, release the lasso and drop the buoy back in.
I have a pick-up buoy on the strops with a line to each. Pick up the buoy and both strops emerge.
Lakesailor
15 Feb 2005
Near Here
That's an ideal situation (bit tricky with a lot of windage, especially if you have sailed onto the mooring).
However lots of buoys have no top loop now. I didn't get one last time I had a mooring laid and whilst I could have complained and had one substituted, the benefit of not having the topsides battered by the ring won out.
I have, in the past, wrapped the ring in self-amalgamating tape which solved most of the abrasion problems.
snowleopard
Oxford
Then again, there are those who are considerate of other people's property and those who don't give a monkey's.
fireball
15 Nov 2004
Generally speaking private moorings will have pickup buoys so the lassoing method won't come into it for most of us.
Seriously though, if a standard method of making initial contact is damaging buoys then there are two things that need to happen
1 the rya need to TEACH crews that it's not always the right way.
2 the people who make mooring buoys need to consider lassoing and ways of preventing damage from this technique.
For now - if you have such a buoy then please mark it clearly with "no lassoing" then at least there is no excuse. I would also suggest that you change it for one that can be lassoed next time it gets changed.
alant
30 May 2001
UK - Solent region
There was a group of buoys in the Solent where one or more sailing schools liked to practice the technique. It cost the owners a fortune in maintenance.
By all means lasso your home buoy but if you borrow other peoples moorings, please have the courtesy to use a less damaging technique. All may seem well when you leave after your stay but the owner returning to a half-deflated buoy isn't going to thank you.
Those were the ones around Calshot - sea schools banned, because too many buoys damaged.
