lcochrane
New Member
Does anyone have thoughts on the pros and cons of lengthening a shallow draft cast iron bulb keel (4 foot 3") on a 34.2 ft Jeanneau.
I'd contact Jeanneau and discuss the project with them. See what the designers got to say on changing the shape of the boat.Does anyone have thoughts on the pros and cons of lengthening a shallow draft cast iron bulb keel (4 foot 3") on a 34.2 ft Jeanneau.
How would you go about it?
Cut it in two horizontally above the bulb and weld in an extension?
I'm no expert but sounds a bit extreme to me.
Trouble is if you start messing with one parameter you change others. If you can deepen the keel but keep the weight, the centre of lateral resistance and the centre of gravity in the same place, you'll get away with it. If you end up with an increased righting moment you'll put increased strain on the standing rigging (she'll carry more sail in a given wind strength) and you might need to beef up shrouds, stays, chainplates and keel bolts. If you add weight, your power to weight ratio will suffer - she'll be slower, especially in light airs. If you move the CLR you might introduce hard-to-cure lee or weather helm. Not easy, and I'd consult an naval architect rather than the forum before starting work.
There were two options for the keel, either the shoal draught bulbed fin or a deeper keel. The bulbed fin has more ballast than the deeper keel to compensate for the shallower draught.
This boat was built with two different keel options, the shallow one being the heavy one..
Indeed - I've heard of people changing the draft of a boat by replacing the keel with an alternative from the original manufacturer. I'm pretty sure there was a discussion thread on exactly this subject on the Jeanneau Owner's Forum.
It is going to be expensive - keels are ruddy heavy things, so you can't simply unbolt the old one, lift it away, lift in a new one and do up the bolts. We were considering buying a boat a year or so ago that had been grounded and had a leaking keel joint. I made enquiries with several boat yards about the cost of having it dropped and reseated - and they were all looking for between £1000 and £2000 just to do that. Add in the cost of the replacement keel - I can't imagine that Jeanneau would sell you one for less than £5000.
I suppose that you may be able to find someone with a deep draft version of the same boat who wanted to swap with you - but you would then be talking twice the cost of dropping and refitting.
I'm not very happy with the idea of a spacer - won't this put a large bending moment on the keel bolts when heeled?
