PabloPicasso
Due to Brexit I had to change to a non UK based broker. As a result I had to get a new survey. the surveyor recommended pulling the aft most keel bolt on my 26ft sailing boat, something i was not looking forward to attempting. I've heard all sorts of stories about bending pry bars/scaffold pole/etc and how difficult it is to get the leverage in the small space of a cabin sole.
Anyway, as it turned out it was very easy to do with a bit of know-how and the right tools.
The right tool is, I have found out, an impact gun. It made light work of removal and reinstallation of the keel stud.
Here is a link to my youtube video of same. Sorry there is no commentary, I'm a bit of an IT numpty. Have a look from 47sec in. It actually took about 5 or 6 minutes of hammering with the impact gun, and then the bolt just came out. Thankfully it was in good condition, so we just cleaned up the surface rust and put it back.
I can see why the surveyor wanted me to pull the bolt, it looked really crusty. However, all the crustiness was some sort of coating that was peeling off. Once cleaned up the bolts/nuts were fine, only a bit of surface rust. Not bad after 40years. You can see this clearly in the video clip if you watch the whole thing
