Rhylsailer99
I've just noticed the varnish had a crack so pushed it and found rotten wood underneath . What's the best way to repair it , do I use some kind of epoxy wood repair kit.
Breakage of the tiller could have very serious consequences.I've just noticed the varnish had a crack so pushed it and found rotten wood underneath . What's the best way to repair it , do I use some kind of epoxy wood repair kit.
+1. I once had the screws holding the tiller-pilot pivot tear out in a gust of wind, and it gave me a very exciting few minutes until I got things back under control - and the tiller was intact, so I just had to get back to it and grab it (I was single-handed and doing something on deck). I fairly soon made a new tiller, even though the old one was still sound - I just didn't trust it not to happen again. If the tiller breaks, you're without steering, and on a tiller steered boat, there often isn't a simple way to fit an emergency tiller; there isn't on mine.Breakage of the tiller could have very serious consequences.
I would want to know the extent of the rot before deciding what to do.
If it is more than a slightl imperfection I would either insert a new piece of matching timber (using epoxy as an adhesive) or make a new tiller.
Probably not particularly necessary, but how about making a nice new one?
Nice bit of oak for strength ?
Ash sounds good and strong and with good bendyness .I was advised that Ash is the right wood for a tiller as it has a long grain and bends instead of snaps.
I had a tiller failure at speed in a Laser 2 dinghy off Cumbrae.... I got wet. I had an Enterprise dinghy tiller greenstick fracture off Nefyn. It got us home safely, hence the trip to the village woodworker who made me a new one in Ash. In a previous life he made Mosquito aircraft components.
Nice.I made mine out of alternating layers of ash and a tropical hardwood that i happened to have. The very simple jig was simply a 2 inch thick 8 in wide board with a curvey cut down the middle then I sandwiched all layers between with sash clamps. Epoxy glue. It was amazingly easy to do. I just use a spokeshave to do the square to round over the length.
With the butt end in the vice it had all the yield and flexibility of a piece of steel of same dimensions!
I chose ash for reasons given above, but I am aware that ash has very low natural durability so it must be well protected
Delighted to see the spirit of practical boatowner is still alive!Axe handle?
Ours is an ash shovel handle from local hardware store. The tiller extension is the top end of the handle of a garden rake. Ash is lovely and strong, yet flexible and feels good in the hand.Delighted to see the spirit of practical boatowner is still alive!
thatMy tiller was a bit dodgy when we bought ours. A curved, laminated one. I didnt fancy the expense, so I wrapped it in carbon and epoxy.
