scottsail
I have a Jabsco Manual Toilet model 29090-0000. I am able to pump water into the bowl, however pumping water out is a problem. The pump is not leaking at the top and I hear pressure building up and eventually the pump handle becomes really stiff. I believe that the pump is working okay, however I cannot figure out where the blockage is and how to fix it. I've noticed small pieces of grit appearing in the drain of the bowl since I've been working at trying to clear the system out. Any suggestions on what to do next ?
Thanks.
Thanks.
