johnalison
So its all really a non argument unless you break the law and motorsail without the cone. And you wouldnt do that would you?
Often
The machinery used for propulsion is not just the engine - it is the gear box and prop shaft and propellor...
If the propellor is not being driven by the engine then the vessel is not power driven.
There is no ambiguity in rule 25, it says "...when also being propelled by machinery...". An engine running out of gear is not providing propulsion and a cone is not required in that situation. I think that shows that the ColRegs intend for "in use" to be interpreted as in "propelling" not just running.When using the small ships channel in Portsmouth Harbour one is obliged by law to have ones engine running if you have one.
There is nothing in the rules to say it should be in gear. More often than not if tacking is not required my engine is just ticking over and out of gear.
I've never seen a cone in the small ships channel.
A boat sailing with the engine in neutral is still sailing, it is not motoring - just like a motorboat with it's anchor down and it's motor running in neutral is still anchored and not motoring.
Rule 3 is also quite clear on the definition of a "power-driven vessel" - it means "... any vessel propelled by machinery". A boat sailing with it's engine in neutral is not being propelled by machinery, it is being propelled by it's sails alone.
It depends whether or not a cone is hoisted! Or a white light is showing to the forward sector!
Because that is what other boats have to rely on.
Wrong a vessel anchored is moored or made fast to the sea bed, some where in the rules that is covered... There is a big difference... Different day shapes different lights...
A PDV with engine running but not engaged is underway but not making way as is still obliged to follow the rule of the road... It is not NUC or RAM it is drifting as it chooses to if risk of collision develops he has to engage engine and react... His lights of a night are not special he is just a PDV.
It is mute point about the sailing vessel, but I consider myself a PDV, I would still expect it to act like one although 90% don't that goes back to my post #5
As it is the argument is pretty mute as jimbaerselman said before:
The rest is just talk.....
A boat not being propelled by machinery cannot be a power driven vessel. An engine in neutral is not providing propulsion.
Far from agreeing with you, you state "A boat sailing with the engine in neutral is still sailing, it is not motoring - just like a motorboat with it's anchor down and it's motor running in neutral is still anchored and not motoring." That is simply NOT the case, an anchored vessel is just simply not relevant.Don't know quite know what you are arguing there, I think you agree with me
I don't think it a moot point at all - and the rest is just waffle...
They seem clear to me too.The colregs seem very clear to me. The fact that there is any debate suggests that people need to read them.
Far from agreeing with you, you state "A boat sailing with the engine in neutral is still sailing, it is not motoring - just like a motorboat with it's anchor down and it's motor running in neutral is still anchored and not motoring." That is simply NOT the case, an anchored vessel is just simply not relevant.....
Again I go back to what I said earlier if I had engine running I will keep out of his way and depending on the circumstances of the case my opinion of him will be lower....
Oh and having just chatted with a master mariner if you do similar to and get in the way of his ship he will just think what another idiot WAFI....
