geem
I have just upgraded it to1020wYou need space for 800w! I have 250w.
Vango Sizzle Double Induction Hob https://amzn.eu/d/4HOh8zzYes, I was aware of the turntable thing and have found one suitable. What brand is your hob?
I think those are 800w. We now have a pair of 2000w induction hobs. We are limited to 3000w on the inverter so need to ensure we don't use them both on full power. It's amazing how much quicker it is to boil a kettle on a 2000w induction hob compared to using a gas ring. Quite happy to lose the gasVango Sizzle Double Induction Hob https://amzn.eu/d/4HOh8zz
Very neat and cheap enough and small enough to try out without removing the diesel hob. Pity Amazon France only seem to have the single one so I’ll wait until our next trip home.Vango Sizzle Double Induction Hob Amazon.co.uk
We use ours regularly at 2000w to boil the kettle, etc. We plan to install a panasonic combination oven this winter. I will gimball the cooker and install a single 2000w induction hob on top. The second hob lives in a shelf at the back of the cooker. This one will only come out when at anchor, if we need it. My wife has become a dab hand a cooking with a single induction hob over the last 18 months, since we don't like cooking with gas in the Tropics. The gas really heats the cabin up.Yes 800w each, we chose them because of this, they work well and are still quicker than gas, we find at home we really use ours above 800w setting anyway. They also are slightly smaller and fitting on top of the lift up covers I have over the gas burners
We have been using 385Ah of lithium @24v but it's getting increased to 560Ah @24v. It gives us equivelent to over 2000Ah of lead at 12v but only weighs 85kg. My 4 Trojan T105 lead batteries that we used to have, weighed 112kg but we only had a usable 225Ah at 12v (assuming 50% depth of discharge). So with lithium you get 4 times the capacity for 75% of the weight, in my case.What battery systems are you using for electric cooking? I would imagine a large bank is needed?
Yes, I looked into Lithium (earlier post) but the need for power to my water maker via the invertor meant that I would need to have an expensive b2b charging system. Not really worth the expense or hassle.We have been using 385Ah of lithium @24v but it's getting increased to 560Ah @24v. It gives us equivelent to over 2000Ah of lead at 12v but only weighs 85kg. My 4 Trojan T105 lead batteries that we used to have, weighed 112kg but we only had a usable 225Ah at 12v (assuming 50% depth of discharge). So with lithium you get 4 times the capacity for 75% of the weight, in my case.
For lots of people gas and lead batteries is fine. Our problem is that the heat of the tropics is very hard on lead batteries. Replacing batteries in the Caribbean is expensive. I think now, more people have lithium cruising the Caribbean than lead. Thr liveaboard life is hard on batteries as well. Since I build my own batteries, the cost of lithium is lower than lead but you do need to do the upgrade to the rest of the system that can be as expensive as the lithium batteries. It's not the same for everybody. A couple of friends added lithium to their Jeaneau and Beneteau yachts with minimal expense. They already had large solar installations, mppt solar regs, smart shunt and 12v watermakers. They simply added lithium, and didn't bother with dc/dc chargers as they run off solar alone. They aren't electric cooking yet, but when they do, they will add dc/dc and larger inverter. Both friends who took a little bit of persuading to go lithium now describe it as a game changer. They are now telling everybody else to go lithiumYes, I looked into Lithium (earlier post) but the need for power to my water maker via the invertor meant that I would need to have an expensive b2b charging system. Not really worth the expense or hassle.
I will stick with gas.
Energy production rather than energy storage is normally the limiting factor in determining if electric cooking is viable, but there is still a need for a reasonably sized battery bank.What battery systems are you using for electric cooking? I would imagine a large bank is needed?
I would add that when you convert to lithium, you often see a doubling of your solar production since many cruisers often say their batteries are fully charged by midday. Having the batteries just sat on float all afternoon wastes a lot of solar productionEnergy production rather than energy storage is normally the limiting factor in determining if electric cooking is viable, but there is still a need for a reasonably sized battery bank.
If you have a 12v battery bank below about 500 Ah (if lead acid) or 300 Ah (if you have lithium), any large amount electric cooking is likely to be difficult when away from shore power or without a generator.
At lower settings electric cooking is not a very high current draw so doing some types of electric cooking will be possible with more modest systems.
Portable induction cooktops are inexpensive so if you already have a reasonable sized inverter and some spare energy production you can dabble in electric cooking with little cost or installation hassle. However, there is little point unless you are producing excess electrical energy. If you need to run a generator (or run a generator more) to replace the energy, then propane is a more suitable cooking method in my view.
Is there some way to use this to heat the water?I would add that when you convert to lithium, you often see a doubling of your solar production since many cruisers often say their batteries are fully charged by midday. Having the batteries just sat on float all afternoon wastes a lot of solar production
We heat the water off the inverter and immersion heater. It takes about 500Wh to heat water in the Caribbean for showers for two.Is there some way to use this to heat the water?
When we converted to lithium, we went from harvesting about 2kWh to about 3.5kWh per day.We heat the water off the inverter and immersion heater. It takes about 500Wh to heat water in the Caribbean for showers for two.
Do you feed from the inverter directly into the boat's 240v supply? I keep them separate.When we converted to lithium, we went from harvesting about 2kWh to about 3.5kWh per day.
200w of solar is enough to make hot water for us
I have a rotary switch that switches between shore power and inverter. Once switched to inverter, it will power all the circuits in the boat except the battery chargers. They are inhibited via the rotary switch.Do you feed from the inverter directly into the boat's 240v supply? I keep them separate.
