AngusMcDoon
In 20 years of ownership I sailed nearly 50k miles on my 10hp outboard powered Dragonfly, from the Scillies to the Shetlands and everywhere in between. It can be done.
Here are some experiences...
- Never had any electrical problems, never had a failure to start, never had to change a sparkplug in a bouncy sea. I had one fuel pump diaphragm split. In 20 years that was all.
- External fuel tank. Refill using a siphon pump. No spillages. Not difficult.
- No diesel bug. Petrol doesn't seem to suffer from this. If there's any crud in the tank, lift it out and remove it. 5 minute job.
- Approximately 20 NM/gallon in calm conditions. Didn't see anything like some of the fuel consumptions posted here - they must be for 2 strokes.
- Extra long leg stopped the prop coming out of the water. Honda, Tohatsu and Selva makes these.
- Fine stopping in astern. Fine steering in astern. Linked tillers meant I could do a 180 degree turn in 2 boat lengths, forwards or backwards.
- Longest non-stop trip under engine was Pwllheli to Troon, but fuel got low near Girvan so went in to refuel. Over 200 miles.
- The first engine wore out after 30k miles. Replacement was £2k. Fitting took 5 minutes. A gorilla sized mechanic from the shop lifted it on for me.
- When you decide you need a new one, delivery is a few days. It can be months for an inboard diesel. (Things may have changed with current supply chain problems).
- Maintenance is easy and minimal. To anyone who tinkered with Japanese motorcycles in their youth they are similar. I can cope with carbs. I wouldn't know where to start with a high pressure fuel system.
- I never locked it. The mount was through bolted to the hull. Enough to stop any casual thief if not a determined one.
- I didn't hurt my back lifting it off because I never did. Bolted on, and it stayed there.
- The charging output and a 60 W solar panel allowed me to run a small fridge, autopilot, instruments etc all summer.
- I got to know where petrol was available. On the Scottish west coast the islands are better than the mainland usually.
- I could lift the prop and leg completely out of the water. Anode unnecessary and fouling non existent. No prop drag. Replacement prop cheap if needed.
- Electric start which was always instant, but hand starting was easily done as well. This negated the need for a separate starting battery.
- All fuel and oily smells are kept outside. The cabin and bilges never smelled like a stinky old engine. This is an advantage you don't often hear mentioned.
- I picked up ropey fishing detritus on the prop occasionally. It's a 5 minute inconvenience with an outboard.
- While the impellor can't be replaced at sea they rarely seem to fail on outboards. I replaced them every 5 years but there was never any damage or wear.
- It's important to keep weight down on small boats, especially multis, and not having a 200kg lump of cast iron lurking down below means I can carry extra supplies of Pringles.
It's not all inboard diesel good, petrol outboard bad. There are advantages and disadvantages to either.
