Crinan12
Hi all
I removed my heat exchanger/exhaust from my engine because I snapped an exhaust bolt and i want to be able to sort it out at home.
But I have some questions please:
1. There seems to be some damage corrosion (?) at the area where the bronze heat exchanger cap bolts onto the heat exchanger body. Why would that be the case? I change the pencil anode regularly, but there was 1 occasion when I went to change it and the anode had fallen out of the brass bolt thing so perhaps the damage occurred then?
Anyway i suppose my question is if it seals OK do I just do nothing or should I replace the heat exchanger body while I have got it off? (I am guessing it's an expensive part!). Or any other type of repair to this area?
2. I was going to replace my high rise exhaust as a precaution but it has been welded at the top as if it has been modified - perhaps to make it fit? Which would mean it is not an exhaust I can just order from Beta or whatever? Engine fitted 2007, 500 hours - I have read the exhausts can corrode so I'd rather replace it if it's not going to cost a fortune.
3. Can I leave my boat with the flexible exhaust hose the way it is? I.e. am I in danger of sinking my boat?
Thank you in advance
Douglas
Douglas
