hannahcamille
I have a macwester 28 with a Yanmar 2gm20f engine. I’ve just done a service and everything was going so well until the last bit where I changed the fuel filters. I’ve watched lots of videos of people doing this specifically with this engine and I just can’t get the engine to start. Here’s what happened:
1) Primary and secondary fuel filters changed
2) Primed first using the fuel pump on the engine (which doesn’t really feel like anything is happening when using it)
3) Primed by turning the engine over (someone recommended doing this with the decompression levers turned upwards and the seacock off to avoid flooding the engine with water)
After first attempt, the engine started for a few seconds and the stalled. So I tried to bleed the engine again with the first method.
There are bleed points on both filters and at the injectors, all of which when opened seem to be pouring out fuel with no visible air bubbles.
Now the engine won’t fire up at all.
I know it’s the fuel because it was working fine before I did this part…
Has anyone got any ideas or experience in bleeding this type of engine?
I would be so grateful for any input!
Thanks![Smiling face with smiling eyes :blush: 😊](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60a.png)
