Anthonyexmouth
Hi, I've fitted transom mount transducers in the hull in the past using epoxy and silicone and have all worked well. Does anyone here know if the newer down vu/side vu type transducers work well if mounted like this?
It's downscan that i really want, not that bothered with the sidescan, it's nice but would probably never use it.You could try Salar’s method Installing a transducer inside the hull - new method - Boat Angling
Not sure about downscan but sidescan definitely doesn’t work with the transducer shooting through hull.
The foam is to keep the t/d at the correct angle and to stop it moving around.It's downscan that i really want, not that bothered with the sidescan, it's nice but would probably never use it.
I saw that foam method but dont really understand the foam bit? I've done a similar install but just flooded the box with castor oil and then sealed it
Really hope someone comes back and says that the downvu/clear view or whatever that wanna call it works. Like i said earlier, only working in shallowish water so fingers crossed.
Nice one, sounds like it worked out well with the new location and less likely to get damaged in the hull.Well, bit of an update, finally decided to try the Garmin GT-52 transom mount in the hull. Decided the easiest way was to try it in the bilge before pumping it out so it was in water next to the hull. Had a run in the river and Clear-Vu worked as well as it does on the transom up to 10m. Now I know it works to that depth I might make the effort and bed it on some silicone and try a bit deeper. realistically, the boat spends 95% of its time fishing in depth between 5-30m so hopefully, this will be fine. It's gonna be nice not having the transom mount if this works out.
Yeah, always worried about having things hanging off the back. Hope it works when I pop out into deeper water. Another upside is a cleaner image on the traditional sounder as there's no prop wash interference , but propwash never showed up on the Clear-Vu when it was transom mounted.Nice one, sounds like it worked out well with the new location and less likely to get damaged in the hull.
Works really well, can't notice any difference from when it was transom mounted.Just wondering how this has been working out with Clearvu especially ?
Thanks I was assured by Garmin that only standard mode would work and Clearvu won't work at all as it needs to be in direct contact with the water.Works really well, can't notice any difference from when it was transom mounted.
