Can you not look at the one on the otherside? If it was riveted presumably you want it so again, but as a quick fix and nut and bolt would do a job - making sure to use some method to stop it comings loose (locktite, nylon nut, etc)Hi, the thing that my lazy Jack's run through has come off my spreader.
What's the easiest way to re- fix it?
Do I need to buy a riveting tool?
Pop rivets - which is probably why its come away after the flange heads corroded .... the white crud tells me that !!
Or self-tapper screws.
Make sure that Duralac or similar barrier is used as that pad eye is likely stainless and your spreader is anodised alloy
Thanks, self tapping screws sound within my capability.
Had never heard of Duralac - another thing to buy!
Pop riveting is not hard, and for a small job like this it doesn’t have to be fancy or expensive equipment. Even a muffin like me can manage it when sitting in a bosun’s chair. I wouldn’t have thought that the gauge of metal on a spreader would make it a good base for s/t screws, especially as the stress will be longitudinal, so to speak.
Thanks. My mast is down so should be easy enough.
No I was being stupid I was forgetting spreaders are hollow so assuming rivited through anyway.The other one is riveted, just wondered if something an easier way as I don't have riveting stuff
If I can use screws that is good!
Not sure how nut and bolt would work because it's my spreader - unless I'm being stupid
I do have a topping lift and it's never occurred to me that the lazyjacks could be taking the weight of the sail and boomIf the OP's boat has a topping lift and not a boom strut, there is always the possibility that, as a result of accident or carelessness, the lazy-jacks may suddenly be bearing the weight of the boom and the furled mainsail.
For this reason, it seems to me that they and their point of attachment must be at least as strong as a topping lift.
I don't think a single pop-rivet into an aluminium spreader is good enough.
I would either do as johnphilip recommends (post #12) and through bolt or, as I have done on my boat, not have the lazy jacks suspended from the spreaders at all but instead from cheek blocks riveted with 4 rivets each to the sides of the mast.
What would you use to sleeve the eyebolt?A single hole right through the spreader is hardly going to endanger the structural integrity of the spreader. Put a small eyebolt right through the section, easy to sleeve it to provide isolation. Either pass the lazyjack through the eye or shackle a mini block onto the bolt.
For example Proboat Eye Bolt Commercial - Stainless Steel
But do use a Nylock nut above the eyebolt or at least distort the thread so the nut cannot rattle off.
