Ian_Rob
I am sure that in the dim and distant past I have seen white horseshoe buoys that have a texture or grained finish rather than a white glossy finish. Am I imaging this?
Horseshoe buoys are almost useless, they're a relic of a bygone age. There are better solutions today.
Well, I have read this, including one or two threads in this forum but not much substantive fact. What solutions do you think are better? I would have thought that there is value in having something buoyant that one can swim too and which is flagged but....?
I like the idea of the JonBuoy that can support the casualty out of the water but they are 20 x the price.
That depends on what you are trying to solveHorseshoe buoys are almost useless, they're a relic of a bygone age. There are better solutions today.
I would like to find some new yellow ones.I am sure that in the dim and distant past I have seen white horseshoe buoys that have a texture or grained finish rather than a white glossy finish. Am I imaging this?
The design has not been improved on
I've also noted that, the same with waterproofs that I used to wear twenty years ago ?to the point that you can't fit them round a typical torso.
A modern alternative?
If your boat is set up so that you can't get the buoy over the side quickly, that's not really a design flaw with the buoy.Life jacket wearing is fairly universal now, so the need for the horse shoe as a floatation aid is almost redundant. Even marking MOB position a horseshoe and Dan buoy combination is shit. The majority can’t be deployed in a meaningful time frame to Mark MOB position. Also personal AIS solutions are far better at returning to the casualty, even though expensive.
Apparently the even older life ring had better functionally to get the required support. It flips up when you grab the side allowing one top poke the head and shoulders through it. So I have been told.
I snapped a horseshoe forcing it around my rotundness.
