Mark-1
Not entirely correct....if there was vacuum inside the bowl it wouldnt work. The bowl has an overflow/breather. If you look at your carb the main jet tube has a hole drilled approx 8mm from the bottom. The fuel flows into the main jet through here. When the fuel is lower than the hole it stops running and still has fuel left inside the bowl
This useful and interesting insight has stayed with me since yesterday. As you say there must be fuel in the bowl. So as soon as I take my outboard off and lie it on its side (Or even turn it upside down lifting it over the rail) fuel is going to end up everywhere including back in the jets.
Clearly there will be less fuel, which is nice, and with the engine cooler so most will hopefully drip back into the bowl when the engine is stood back up. Even so, it seems running the carb dry isn't the panacea I thought it was. (Well, I kind of knew that, my fuel tap was stuck 'on' for three years and my carb was never run dry in those years. Gave no problems.)
