merjan
I was fixing the kill switch of an old 2hp 2-stroke Yamaha outboard (6a1), and "while I was at it" I cleaned the waterways, and replaced the impeller and the seals of the lower unit... and ended up with water leaks into the lower unit. This is how new oil looks like after running the engine for 5 minutes
Now I'd like to figure out whether the amount of "froth" in the oil is acceptable, and if not, to figure out how to rank the potential culprits. So firstly, looking at the picture, would anyone say whether I definitely need to fix this or that's fine"?
As for how I installed the new seals, looking at this diagram
Yamaha Outboard Parts - 2 MHS 2B (6A1) / Europe (030) / 1999 - Lower Casing & Drive 1
I put two seals above the impeller housing and one below under the bowl where the impeler sits. There are two types of seals, one type is slightly slimmer than the other. It wasn't clear in the diagram which one goes where. Judging by what I removed, I put the two slim ones above the impeller housing, and the one thicker one below it. In both cases "lips" have been facing towards me as I tap them into place, ie the flat sides of the seals away from me. Does that sound right to anyone who remembers how these go?
I would be very grateful for any advice!
