truebrit
Went to Milford for a few days, left boat on mooring for 2 days, went to bring her in ready to trailer home and found water halfway up bell housing! bilge pump switch blown probably luckily really as battery just had enough life to fire her up and get to shore. When on trailer noticed water coming out from transom /sterndrive joint I presume rubber gaiter failure. One lesson learnt,in future larger fuse in bilge pump circuit and carry a manual pump! also use a seperate battery for bilge pump. Now I face stripping sterndrive down ,its an OMC cobra and looking at the manual looks like a real fun job, anybody done this or have any advice, I know get a professional would be easiest!! Is it likely that the flywheel has sprayed water all over the starter (it works ok now) if it has the starter is likely to rust up rapidly and it looks like a swine to take off in situe. The boat is a 1989 Bayliner capri 1952 cuddy. Any advice would be very welcome or anybody know of an independent marine engineer in Warks/worcs/glos area ? need to get fixed soon as am off to annoy Scotland and Loch Fyne in 4 weeks time!!!
<hr width=100% size=1>Mike....... V8s are sweet music
