captainslarty
N/A
Heads, a subject likely to come up in any liveaboard conversation, wierd, yes, but always seems to emerge at some point.
The best marine head is really a difficult thing to quantify.
For a start, and this is the delicate bit, I dont know how to say it any other way, but.... what size turd is the head designed for ??? /forums/images/graemlins/laugh.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
I was, in a previous life, a paramedic for 14 years with Lancashire Ambulance Service, I remember a lecture in A&P about the ´normal and average´turd.....
Sometimes, depending on diet the results can be rather different to the norm.. this often causes problems for marine loos... as well as the producer /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
We have the excellent blakes lavac on board, but it is VERY expensive in the great schem of things to upkeep, and not a pleasent job to repair, to say the least... the problem is the diaphram in the henderson Mk5 pump unit.. and, the size of the inlet and outlet valves, sometimes, it just cant cope, or if made to cope applies far too much pressure on the diaphram. We end up replacing the darn thing at around 6 month intervals. The job of stripping the pump, rebuilding, the cost of the service kit et al is not good..... and I dont really want to clear every high vacuum pressure situation by HAND due to the non average, carefully factored in design stage deposit......
So, how to make the if not perfect, then at least far better heads arrangement....
This is the plan, will let you know the results...
Dump (No pun intended lol) the Mk5 as the primary unit and have it available as secondary only..
Fit a Macerator pump (Jabsco) to the bowl drain, use this electric option to evacuate the bowl (Not bowel /forums/images/graemlins/cool.gif /forums/images/graemlins/blush.gif) and Bobs yer aunties husband. The suction of the mac pump allows the existing lavac vacuum system to function, and life is easier. The calcium build up in pipes is reduced, in theory, and is of less consequence with the mac unit anyways. No more endless beating of the pipes on the pontoon (I am sure other liveaboards will have been there)
I intend to valve the unit to allow the óld´manual system to be used if necessary to a holding tank.
AND make sure the button to ignite the system is not available in the ´prone´position, ouch !
Moohahahahaha !
More power Egor !
Moohahahahaha !
More power Egor !
