Portofino
Yup mapism, cat c32 has no EGT. There are npt ports ready to fit a sensor if I want, and I'd use maretron sensors to feed the info to n2k, but I'm not convinced of the need and don't have time. I'd need 4 sensors and that is punchy amount of £££ because nothing about Maretron is cheap!
Anyway, % load factor gives me a good enough proxy. If the engines reach manufacture rpm with the boat loaded, which they do, and if that shows 100% load factor, then if I have about 70% load factor at 70% max rpm, I can conclude that EGT is likely ok. Conversely if the engines themselves are ok but 100% load factor produced 70% max rpm (=overloaded or over propped) there is something wrong, and I don't need to see an elevated EGT to know that. Happy to hear alternative theories but that's my off-the-cuff thinking
I need to play around bit ,with it - but from memory the load is not linear with speed /rpm -nor the EGT .
As it accelerates at 9-10 knots hits a bow wave as D speed is exceeded -so load shoots up faster than speed ,
Pops up at say 17-18 knots initially -load increases --- then settles back as rpm increase as it s now planing and min drag .
Once planing then load inc is linear to max .
EGT -seems to be a combo of load and when turbo,s spool up ie 1300 -1500 rpm EGT shoots up Drops back off the plane .
