MapisM
Yes I was, but I see your point!P. assuming you're replying on my questions above...
Moulding #1 on its own with metal incorporated in the sandwich to bolt the roof runners to.
Exactly my thought, also for the trim panel, if that is Epoxy-ed in position it makes the assembly A LOT more stiff and strongand then assemble the two mouldings with a two part structural epoxy to end up with a double sided moulding.
After uploading the photo I realised there are a couple of lines around the rib area that shouldn't be there but I am sure you can see beyond the drawing and get the concept.
Apologies if anything isn't clear.
Bart, have you dismissed the thought of getting a polystyrene mould milled on a 5 axis s machine? Cost of this has crashed over the past couple of years.
The concept is very clear Paul,
Just one thing I don’t understand;
The moulding 2 goes also in the section above the trim panel,
So in that zone (right side of the drawing / assembly) imo we don’t need a moulding 2, moulding 2 can be half the size as in my drawing ?
The epoxy with mat- outside skin + core + epoxy with mat - inside skin can all be done in moulding 1, as the rough area is covered behind the trim panel.
interesting Idea Paul,
or 3D printing ?
I'm not sure if the size I need is available, but going to investigate this method
answering Vas and Mapism Q,
for smoothing the surface: decent 'filler' primer, and then spray painting ?
I think this route more expensive than the 5-axis cutter.
I was suggesting cutting the mould in the polystyrene, then lay up in the normal way, gel coat then grp or carbon.
I think it much cheaper and easier in polystyrene Bart. You can get blocks of this, and glue together to make the full mould.I shurely will investigate the 5axis cutter P ! thanks !
do you have experience ? why not in wood, MDF or ... ?
yes OK you're right about the Polysterene,I think it much cheaper and easier in polystyrene Bart. You can get blocks of this, and glue together to make the full mould.
I am on hols this week, so away from the office, back next Monday, so can ask the experts then, if you can wait that long? Sounds like you have a potential solution close to home though?
Great, I'm sure between the forum and your local guy, we can make this work��yes OK you're right about the Polysterene,
If we can involve the GRP manufacturer they will shurely give advice, or do the mould themselves, etc..
project is completely in between the regular job, so no hurry,
this weekend I'm on the boat, will try to take some detailed dimensions.
I have seen using aluminium profiles feathered in in long GRP overhangs (SQ78 FB over cockpit overhang ? )
how about integrating a alum tube in the side profiles fe 120mm x 60 mm cross section 3mm skin thickness
we can calculate the beding of such a profile
but taking moulding #2 above the trim panel means you can incorporate the ribs in moulding 2 and use the shape and structural epoxy to build up the strength and rigidity of moulding #1. ...
Paul I still don't understand this,
is it not more easy to:
place mould for moulding part nr 1 (upside down) on the work bench,
put in gelcoat and all that,
then firs layers of epoxy and glass mat
then coring material
then more layers of epoxy and glass,
then Ribs (coring material)
then layers of epoxy and glass over the ribs
then
bring the premade moulding part nr2 over the gutter (for smooth finish of gutter on underside)
and when all is dry,
glue the trim panel in position with epoxy glue
so that all because one piece
perhaps I'm wrong on this,
so don't hesitate to shoot
I don't think you are wrong, I think we are both thinking the same things but actioning them in different ways. :encouragement:
Where you are using your trim panel as a structural part of the shape, in my sketch the trim panel was removable to allow cable access etc.
My old mentor drummed it into me that a customer never gets to see the raw (non gelcoat) side of a fibreglass moulding. It is what you don't see that makes all the difference between good and great!
For a one off hand made item, I think two separate mouldings is a challenge, and unnecessary. Sure you can do it if you make plugs/moulds with a 5 axis cutter, but then you are into thousands of pounds because the equipment owner has got to amortise the £1m+ that the machine cost.
or use a gauged wax film from the backside of the initial moulding to generate the secondary skin, gauged wax is c.£10per/msq
The luxury you have here Bart is that this is a one-time only mould, so you can have returns on the mould tool that you remove to get the finished product out - you can even smash the mould off because it is going in the trash anyway. This will help you keep only gelcoated surfaces visible. I would make the thing in a single one-piece mould, made in MDF, spray painted, with faceted compound curves, and then add a simple second trim moulding to hide the raw finish. Heavy brushed gelcoat would let you fix imperfections afterwards. Would cost just time, not big fees for getting the drawing CAD-ed and then renting time on a 5 axis cutter etc etc. Like this for the side sections:
Yep, i agree, if skills are available to make a sacrificial mouldings, go for it! As the old motor sport term suggested; splash moulds are cash moulds!
