drawp
Explain please
Moving the throttle trips the cold start button on the fuel injector pump. So you need to set the throttle first.
Explain please
If you have the facility, it is well worth practicing hand starting in case you need it one day. If you are doing it for the first time I would recommend doing it when the engine is warm, when it should start fairly readily.
Thats interesting. We usually press the button in first, often well before starting.
I'd always assumed that the button tripped when the engine started.
It's not made clear in the owners manual.
Unfortunately, I've only ever seen 2 sep. de-comp levers on a BukhDV20. Perhaps it isn't a common way of mounting the levers.
I think its one of those higher pressure injector engines, but I'm not sure, and that may make it easier.
Two things will trip out the cold start.
1...Engine firing p and governor cutting in.
2...Bringing the throttle back to idle before starting the engine.(Usually the throttle has to be set at least to the click position say about 1/2 speed to set the cold start.)
