GilkyAus
New Member
Hi all
First time poster here and have enjoyed the threads, but now I am stuck and need help. I have a Maritimo 440 with 2 IPS D6 (EVC-C). I have been getting Fault on Joystick and Steering wheel (with and without engines started).
Error codes:
Check Joystick (Starboard)
Mid 164, PSID 64, FMI 9
Check Joystick (Port)
Mid 164, PSID 67, FMI 10
Check Steering Wheel
Mid 164, PSID 133, FMI 9
Error only occurs when turning on Starboard side. I swapped the Joystick leads, steering leads, the X8 harness plugs at HCU starboard to port. Error stays with starboard. As PSID suggest sync issue, I then started thinking about the Multilink side of things. So swapped around the X5 cables. I cleaned all plugs and terminals with contact cleaner. I disconnected various components (Active corrosion a, auto pilot etc) to try and isolate a faulty lead then put it all back together. This seemed to resolve the issue for a few hours but then returned.
Issue only occurs when turning on Starboard. I cannot get it to fault on Port with lead swaps etc.
The boat was serviced recently and reported the issue. They did a software update and auto calibration (assumed) but issues remains. Issue went away for a short trip but has returned.
At first I suspected faulty HCU but after reading the workshop manual and checking codes the fault codes suggest faulty joystick.
For history: replaced PCU to port engine last year. At the same time the tech tidied up the HCU cables behind the helm. I suspected that he may have overtightened things but nothing seemed to be overly strained or kinked.
Any ideas or experience shares would be appreciated.
Jamie
Error codes:
Jamie
