Halyard is no longer in mast!
richardh10
7 Jul 2007
on the move
While my main is being repaired I thought I would take the opportunity to end to end the main halyard. Due to a fatal combination of laziness and stupidity I ended up with all of the halyard at my feet on the deck and no mousing line in the mast. What is the best way to rectify this situation. (I tried swearing at it loudly but that didn't help)
Refueler
13 Sep 2008
Far away from hooray henrys
I had same problem with spinnaker halyard.
An old trick is to get a lightweight person up mast with light line that has a length of bicycle chain ... or long thin fishing weight on line ..... person then feeds it in appropriate sheave at mast head .... only problem then is making sure line doesn't wrap with existing halyards / VHF cable etc. Leaning boat to one side can help ... side that halyard exits mast at base ...
But best way is when mast is down .... which is what I resorted to in the end.
I used an existing halyard that is on same sheave pin next to one to rerun. Remove both sheaves ... masthead and also at mast base. This then allows you to bind with tape a light line to halyard mid point- leaving sufficient halyard spare once pulled all way, if necessary connect light line to this just in case - and pull both .. once started to pull and both inside mast - replace top sheaves with halyard back to correct and light line where you want to rerun halyard. When exits base of mast ... split lines and replace sheaves. Pull back other halyard to its normal and make fast. You now use light line to rerun that halyard which came out ...
Job done.
I've tried it ... seen others try it ... and it rarely works or you spend hours before it actually works >>>>>> stiff fencing wire - what happens is it usually catches about where the spreader fastenings protrude into mast ! Especially that some masts actually have an anti-compression bar there !
capnsensible
15 Mar 2007
Atlantic
Did one on a friend's yacht, Beneteau 331, a couple of weeks ago.
One in bosuns chair up mast, one winching.....used topping lift, right size, me, well, supervising. :)
Dropped a thin line down inside the mast weighted. We had prepared a bit of wire with a hook bent in to retrieve line. Bit of jiggling and hey presto! Rolling hitch with extra hitches on halyard wrapped in duct tape.
Job done, 30 minutes.
Good luck, like most boat jobs it's a lot easier than you think. (y)
jaminb
7 Jan 2021
Having washed my main sheet in the washing machine last week I thought I would treat the main halyard to a wash this week.
I now have the halyard hanging out the sheave and a jammed mousing line! Kicking myself for not taping the knot. Anyone know a cheap monkey in Southampton?
richardh10
7 Jul 2007
on the move
Thats an excellent idea, and one I shall be trying, as I have to make do with what I have on the boat and that doesn't include a bike chain or a metal coat hanger! So I thought for the wiggling bit I would make a large loop from cable ties and see if the mousing line would fall through it. What could possibly go wrong!
MikeBz
22 Aug 2005
East Anglia
The magnet trick works really well, I use a short steel nail tied to the end of the mousing line. I bought a 15mm diameter Neodymium magnet on EBay for a fiver - if you clang it onto a piece of steel it is quite hard to remove it!
wingcommander
25 Jul 2013
.Another possible solution, as described above with additional short legnth of whipping twine tied to lowered end . Possible then to extract with vacuum connected to a short tube.
Refueler
13 Sep 2008
We use Rare Earth magnets to hold hatches ... even wings on RC models ....
Never thought of using any for mast stuff ... I can also imagine that using a magnet avoids line getting wrapped on existing lines / cables in mast.
Just a question : Does anyone still sell those big magnet jobs for salvaging tools etc. out of the oggin ? They used to have a keeper plate on them due to the mag strength ..
Praxinoscope
12 Mar 2018
Aberaeron
Refueler, thé RNLI shop lists the Sea Searcher magnet, so do several chandlers, I have had one lying around for about 20 years and actually used it about a month ago when I dropped the adjustable spanner I was using overboard, got it back in about 5 minutes.
Not to be recommended but a friend who’s ast was down at the time used a small hand-held cross bow and shot the bolt down the mast with the mousing line attached. It did work but not sure I would use this method.
savageseadog
19 Jun 2005
The Magnetron in a microwave oven will contain a couple of reasonably powerful magnets. Find a scrap oven.......
Refueler
13 Sep 2008
SeaSearcher ... was trying to remember the name ...
I've lost loads of tools ... even a battery out of one drill which had failed to latch in correctly .... in my boat channel.
Cross-bow .... pal of mine is ex Latvian Archery Champ .... I had a model airplane stuck up a high tree one day ... he tried for ages with bow to help me get it down. We got Fire Brigade in the end .... how that guy could go up that ladder ... not something I would do ...
Guys on the ground told him to hang on ... and moved ladder for a laugh ..... !!
