tyce
hi im doing my first grp repair so i am a bit of a novice to say the least,
my boat has two cracks both about 10 inch long running vertically and below the waterline.
i have cut out a bulkhead so i can get to cracks on the inside and i intend to put a patch over them on the inside and just gel goat on the outside where i have ground the cracks out, one of the cracks i have had to grind right thro the hull to remove the crack.
would this type of repair be as strong as original or at least be strong enouth for the job or i am i going about it completely wrong.
my other question is one of the cracks when i ground it, i found the fibreglass strands underneath to be dry and flaky is this bad lay up when the boat was made or is it a result of water seeping in the crack because the boat was in the water and in a state of disrepair when i bought it and had been for some time.
hope someone can help as my budget wont stretch to paying some one profesional to do it
