D
Deleted User YDKXO
Good idea but not on a high powered motorboat. For example I'm not going to run one of the 1200hp V12 diesel engines on my boat just to provide mains power instead of a 20kVa genset but it would be a useful back up in the event of genset failure
I don't see any of those as advantages. As we've mentioned before the ability to cruise a few miles on battery power at very slow speed is only going to save a cupfull of diesel. Modern diesel engines are not smoky and with a good underwater exhaust system, not noisy either at idling speeds so I see no major advantage to manouvering with electric drive. Yes there is a small safety bonus in case of failure of both main engines but this would be a very rare occurenceBut here the point is that once you decide to go for an enlarged alternator/inverter and larger battery pack you might as well add an electric motor + controller to the mix for relatively little extra money. Depending on the set-up of the system you can potentially gain the following advantages.
- Limited-range silent low-speed cruising and maneuvering/docking
- All reversing can be done in electric mode, eventually eliminating the need for a reversing gearbox
- Acceleration boost to get up on plane. Electric motors have tremendous torque at low revs; exactly where diesel engines are weak
- Very fine control at low speed and for maneuvering; in principle from 1rpm. Trolling valves for diesel engines become superfluous
- For single engine installations you get a limited battery-electric limp-to-nearest-port capability in case of main engine malfunction. Granted, it's a limited capability, but it is better than no capability
Agreed but we're not anywhere near that point yet. At the moment we have individual builders designing and fitting individual systems and that's bad news for reliability and future maintenanceI don't think this is a valid point. Future hybrid systems would most likely be shipped from propulsion manufacturers ready to plug n' play
Mmm, Seaway is indeed one of the big players but not as a builder but more as a designer/developer of boats. False numbers seems to be a way of life in the boat building industry. If you add up the number of claimed sales that a certain UK boat builder purports to make at every boat show, you end up with a figure several times that of their annual production. I'm not talking about Princess but, by way of example, I understand that Princess make about 300 boats per year. So a start up company like Greenline has already sold more of their 33/40 model than the total annual production of one of the biggest boat builders in the world? I very much remain to be convincedWhy? Seaway is among the big players in the industry..... claiming false sales numbers would surely come back to haunt them sooner rather than later.
