webcraft
I tend to hang on to a full genoa with two reefs in the main for as long as possible (typically up to about 28 knots over the deck hard on the wind). After that I have to furl some of the genoa away, and with between one third and two thirds of it furled away decent windward progress becomes very difficult, the belly in the sail causing the rig to shake and rattle alarmingly unless I bear away onto a reach. However, if I furl more away - so the genoa is one third or less of its original size - then the sail starts to flatten out and it is possible to get closer to the wind again.
In practice this means that I can usually make reasonable progress to windward in thirty knots or more over the deck provided I furl away most of the genoa. A storm jib or smaller sized piece is surprisingly flat as most of the belly seems to be in the middle of the sail,not towards the leech.
How much difference does a foam luff make to the windward ability of a partially furled genoa? Are there any down sides to it?
I will eventually fit a separate removeable inner forestay, but for now am interested in any hints or tips that may improve windward performance in heavy weather using the existing ancient sail or (next season) a new roller furling genoa.
- Nick
<hr width=100% size=1><font size=1><A target="_blank" HREF=http://www.bluemoment.com>http://www.bluemoment.com</A></font size=1>
- Nick
