Getting dried sikaflex from hands?
Minerva
16 Oct 2019
So I’m in a bit of a predicament. Using sika yesterday and managed to get it all over my hands.
Normally I’d just leave it, but I have an interview tomorrow and having black smudgy hands probably isn’t the best look…
So any suggestions bar having an interesting talking point which can be rightfully considered to be example of doing a task without appropriate PPE 😬
John_Silver
19 Mar 2004
St Mary's Island
allatseawithstargazer.blogspot.com
Faced with the same situation as you (15 years ago), I found that abrasion was the only answer……..part-worn scotchbrite-type pan scrubs worked best. For thick build ups, ‘paring’ with a cautiously wielded Stanley blade speeded things up. Go carefully! Swarfega (gritty variety) worth a go, if not too thickly coated. I used that for the ‘final polish!’
…….Subsequently wondered if white cotton gloves, for the interview, might have been the way to go.
EDIT: If all else fails, take comfort from the fact that you are in good company. Sam Goodchild, 48+ hours on from repairing his mainsail with waves breaking over him, attended the Vendee Globe press conference with full ‘Smurf Hands!’
wonkywinch
30 Jul 2018
Hamble, UK
I interviewed someone for a job once and I couldn't help notice the large patch of burned crinkly skin on his forehead. At the end of the interview, curiosity got the better of me so I asked. Apparently the day before he'd wiped his sweaty forehead with the back of his gloved hand whilst he'd been applying Nitromors to strip paint from some doors. Ouch.
Blueboatman
10 Jul 2005
From the Sika instructions pdf:
Meths etc works for uncured Sika only.......Once it has moisture cured itself onto your hands it "can only be removed mechanically," Sika states.
Sure
But I’ve used Sika for many years- it takes a bit longer to fully cure than one might think ..
Messy stuff!
Another option would be to do nothing and wear gloves for the interview.
I have found particularly in dry cold weather -as I'm sure you have too- that it is really important to apply good hand cream overnight after using meths or acetone ( or petrol ) otherwise the skin just cracks ..
penberth3
9 Jun 2017
So I’m in a bit of a predicament. Using sika yesterday and managed to get it all over my hands....
...So any suggestions.... bar having an interesting talking point which can be rightfully considered to be example of doing a task without appropriate PPE 😬
You've got it, wear gloves next time!
stone beach
27 May 2011
A good way to remove hard dried paint from your skin is to work at it with butter, avoids all the thinner/dried out skin issues, you could try that ?
diverd
27 Mar 2020
aberdeen
Toluene takes it off instantly, we use sikaflex weekly and have used it to take it off most things. Not the kind of thing you tend to have lying about
Halo
10 Nov 2009
Wetherby
I was grinding off a skin fitting today and it got very hot. The sika melted and trickled onto my hand. Ouch! Burned skin with a blue layer of sika and a/f. Any tips on whether to scrape, scrub or leave?
